What is Track & Fence Monitoring?
Carmate Carmate
Track and Fence Monitoring are features of Carmate, what is track and fence monitoring?
1.What is track?
①After the interconnection of phone and car, you can see the location information of the car on the phone, so you can quickly determine the location of the car when you get lost;
5870
② After the interconnection, you can update the day's information in the phone and the car. For example, historical driving track and driving speed. Usually there is a big delay in updating the information, but if you buy a track member the delay will be greatly reduced.
5900
2.What is fence monitoring?
Fence warning is enabled when the car leaves the set range within the set monitoring time. If the car leaves the set range, it will notify you in time, effectively ensuring the safety of the vehicle.
5869
Using Carmate to record every trip while safeguarding the safety of your car!
2024-03-29 863 view
Carmate
Carmate
LV3 Grade
28 Fans
1361 Experience
