What is the PVM?
Carmate Carmate
Hello everyone, I am the founder of the carmate app. I will often appear on forums to communicate with you about product experiences. If you have any questions related to cartoon products, you can provide feedback through publishing articles. I will answer them one by one!
The topic I want to discuss with you today is our newly launched feature - PVM.
5228
PVM, short for 360 degree panoramic view, is used to seamlessly integrate 360 degree panoramic views, ultra wide viewing angles, and real-time image information (bird's-eye view) around a vehicle through an onboard display screen, in order to understand blind spots in the vehicle's surrounding line of sight and help drivers park more intuitively and safely.
5928
What is the purpose of a 360 degree panoramic view?
Firstly, panoramic bird's-eye view parking assistance is more intuitive. Whether the front is advanced or the rear is advanced, there is no problem with side parking. It is accurate and in place, improving parking efficiency, effectively preventing scratches during parking, and reducing worries and troubles for car owners.
5929
Secondly, narrow roads, narrow bridges, narrow roads, potholes or obstacles on the roads, and narrow road traffic can be easily solved using 360 degree panoramic view.
Thirdly, looking forward on steep slopes. When your car climbs a steep slope that exceeds 30 degrees, the normal perception is that the sky is ahead, and you cannot see the actual state ahead. Through the screen, you can see everything in front of the car.
Fourthly, eliminate blind spots during turns and improve safety. The camera is located in front of the driver, so you can see the road conditions in advance, especially when the car is turning, and you can also see the dead corners of the left and right rearview mirrors. The application effect of this system is more obvious.
5230
The conditions required to use the PVM function on our app are:
1.At present, all functions in the 360 safety module only support T5Q, TS10, TS18 platforms and have installed the 360 safety solution ("360 safety" or "Zhaotu 360") for use in the vehicle, please upgrade the system and 360 software to the latest version at the same time before use, otherwise the remote function will not be available.
2.Remote live broadcast and remote photography are system upgrade services, and you need to pay to open a live broadcast duration package.
3.The live broadcast duration package is applicable to all functions in the APP that use remote live streaming and remote photography.
2024-03-28 445 view
Carmate
Carmate
LV3 Grade
12 Fans
1076 Experience
