Many users have reported that Dashmate cannot adapt to their screens. The new version is fully adapted to horizontal and vertical screens.
Enter the fault code or fault description keywords in the search box to query the corresponding fault information.
Many users said that they didn’t know what data the small icons. The newly added data floating window explanation function helps you better understand each data.
Click on the area of each data to display
The new version of Dashmate has been optimized for multi-language adaptation. The language of Dashmate will follow your system language, allowing you to better understand the car's data.
For example, when the system language is Russian, the language of Dashmate is converted to Russian.
Finally, this update also optimizes practical small functions
a. Free switching between Chinese and English units, data items such as speed, distance, etc. will be automatically converted according to the selection to meet the usage habits of different regions;
b. Speed display correction, when there is a delay or deviation in the speed display, manual calibration adjustment is supported.
